Radio can't be reset
I’ve been having problem to reset my Force300 and Force200 both manually and automatically.
If the reset by power is disabled in the config, then you must use the button, which on the f300 radios is hard to hit and stay on it. You must hold this button for more than 10 seconds and less than 20 seconds.
But you could also use tinfoil and isolate the radio then use the 169.254.1.1 address to access the radio. As long as the radio does not create an rf link, it does not enforce the management vlan restrictions so as long as you have the admin password it can be accessed.
Also if you have the radio in cnMaestro then you can push a new config to it from another radio with known credentials and configuration. This can be done via config templates or config file upload.
