I have this configured with a mesh on WLAN1 and an AP with security on WLAN2. Everything seems to be working but I cannot change the config of the radio. When I look at config using cnMaestro it looks normal but when I connect using the GUI The enable check box is not checked and some of the fields are empty. When I put the entries in and click save it does not show the saved dialog pop up. Running 3.2.1-r6
Well I tried it with Chrome and still no response with the radio config tab. Last time I had trouble with IE but not Chrome was in the Configure- WLAN tab. When I go to the config-radio the enable in not checked some of the fields are blank but I can fill them in with the choices but when I hit safe there is no blue save dialog that pops up. The config settings I see through cnMaestro look fine. This is version 3.2.1-r6
Maybe I should try a factory reset on this unit. I have several other ones on the same network and under cnMaestro management and they are all working fine. Could be a defective AP.
I am thinking that maybe this radio is broke. I have it as a mesh client. The mesh base shows SNR 41, RSSI -67 when I look at it using cnMaestro. This AP, the mesh client shows SNR13, RSSI -106. Something is really wrong with this AP. I haven't been able to post the techsupport.tar.gz to this forum but I would like to get it to someone who could take a look at it. I will be going to the site tomorrow and will try a factory reset to see if that helps.
