Radio PTP450I ATEX
Dear, is any Housing Different between PTP450i Normal and PTP450i ATEX ? Can you Compare it as Hardware and Software Option ? Best Regards, Ali
Hello Ali,
The housings are identical with the exception of the different part numbers used for the ATEX and non-ATEX versions.
Tim
Can i get PTP/PMP 450i specsheet that state atex hazloc?
We are working hard to get the ATEX/HAZLOC version released very soon.  When these become available for ordering, there will be a spec sheet that clearly states which model numbers are compliant to the ATEX/HAZLOC regulations.
