Radio SM 5700 without power??????
Hello,
I’m with SM 5700 that has no link with distance from the AP, has only binding on the bench, I think is the problem of power, I wonder if anyone has been there and how was the solution.
This is the logo that presented the radio …
00:01:33 UT : Mon Jan 01 2001 : System Log Cleared
00:00:00 UT : Mon Jan 01 2001 : System Reset Exception –
00:00:00 UT : Mon Jan 01 2001 : System Startup
00:00:00 UT : Mon Jan 01 2001 : Software Version : CANOPY 8.1.5 SM-DES
00:00:00 UT : Mon Jan 01 2001 : Software Boot Version : CANOPYBOOT 1.0
00:00:00 UT : Mon Jan 01 2001 : FPGA Version : 102606
00:00:00 UT : Mon Jan 01 2001 : FPGA Features : DES Sched
00:00:43 UT : Mon Jan 01 2001 : Reboot from Webpage.
00:00:00 UT : Mon Jan 01 2001 : System Reset Exception – Watchdog Reset
00:01:14 UT : Mon Jan 01 2001 : Time set
00:00:22 UT : Mon Jan 01 2001 : Time set
00:02:09 UT : Mon Jan 01 2001 : Reset from Telnet command line.
System Startup
Software Version : CANOPY 9.4 SM-DES
FPGA Version : 061808
FPGA Features : DES, Sched
00:02:31 UT : Mon Jan 01 2001 : Time set
00:05:19 UT : Mon Jan 01 2001 : Reboot from Webpage.
System Startup
00:05:39 UT : Mon Jan 01 2001 : Time set
System Startup
00:06:12 UT : Mon Jan 01 2001 : Time set
System Startup
00:18:23 UT : Mon Jan 01 2001 : Time set
System Startup
00:17:27 UT : Mon Jan 01 2001 : Time set
00:23:58 UT : Mon Jan 01 2001 : Reboot from Webpage.
System Startup
00:27:07 UT : Mon Jan 01 2001 : Time set
System Startup
00:50:18 UT : Mon Jan 01 2001 : Time set
01:00:00 UT : Mon Jan 01 2001 : Time set
01:03:18 UT : Mon Jan 01 2001 : Time set
00:00:26 UT : Mon Jan 01 2001 : Time set
00:00:17 UT : Mon Jan 01 2001 : Time set
System Startup
00:11:03 UT : Mon Jan 01 2001 : Time set
System Startup
System Startup
System Startup
00:01:08 UT : Mon Jan 01 2001 : Reboot from Webpage.
System Startup
00:02:03 UT : Mon Jan 01 2001 : Flash Image Update OK
00:02:10 UT : Mon Jan 01 2001 : Reset from Telnet command line.
System Startup
Software Version : CANOPY 10.3.1 SM-DES
System Startup
System Reset Exception – Power-On Reset
00:01:52 UT : Mon Jan 01 2001 : :Reboot from Webpage.
System Startup
00:02:13 UT : Mon Jan 01 2001 : :Time set
00:05:18 UT : Mon Jan 01 2001 : :Reboot from Webpage.
System Startup
00:05:40 UT : Mon Jan 01 2001 : :Time set
00:00:16 UT : Mon Jan 01 2001 : :Time set
System Startup
00:09:54 UT : Mon Jan 01 2001 : :Time set
00:16:36 UT : Mon Jan 01 2001 : :Reboot from Webpage.
System Startup
00:00:15 UT : Mon Jan 01 2001 : :Time set
System Startup
System Startup
System Startup
System Startup
00:04:36 UT : Mon Jan 01 2001 : :Reboot from Webpage.
System Startup
20:19:25 UT : Mon Jan 01 2001 : :Time set
System Startup
22:56:52 UT : Mon Jan 01 2001 : :Time set
23:00:48 UT : Mon Jan 01 2001 : :Reboot from Webpage.
System Startup
23:01:10 UT : Mon Jan 01 2001 : :Time set
System Startup
00:20:09 UT : Mon Jan 08 2001 : :Time set
System Startup
23:23:02 UT : Thu Jan 11 2001 : :Time set
System Startup
19:55:39 UT : Fri Feb 02 2001 : :Time set
System Startup
21:58:27 UT : Sun Feb 04 2001 : :Time set
System Startup
System Startup
09:07:41 UT : Thu Jan 04 2001 : :Time set
System Startup
08:59:00 UT : Fri Jan 05 2001 : :Time set
System Startup
07:14:42 UT : Sat Jan 06 2001 : :Time set
System Startup
09:00:57 UT : Sat Jan 06 2001 : :Time set
00:02:40 UT : Mon Jan 01 2001 : :Time set
System Startup
00:59:24 UT : Mon Jan 01 2001 : :Time set
System Startup
01:08:00 UT : Mon Jan 01 2001 : :Time set
System Startup
System Startup
01:30:55 UT : Mon Jan 01 2001 : :Time set
00:54:52 UT : Mon Jan 01 2001 : :Time set
00:01:28 UT : Mon Jan 01 2001 : :Time set
System Startup
System Startup
08:59:00 UT : Mon Jan 01 2001 : :Time set
14:00:00 UT : Mon Jan 01 2001 : :Time set
11:00:00 UT : Tue Jan 02 2001 : :Time set
20:00:00 UT : Tue Jan 02 2001 : :Time set
23:00:00 UT : Tue Jan 02 2001 : :Time set
18:00:00 UT : Wed Jan 03 2001 : :Time set
22:00:00 UT : Wed Jan 03 2001 : :Time set
00:00:00 UT : Thu Jan 04 2001 : :Time set
00:23:30 UT : Mon Jan 01 2001 : :Time set
System Startup
System Startup
00:31:09 UT : Mon Jan 01 2001 : :Time set
System Startup
00:33:53 UT : Mon Jan 01 2001 : :Time set
System Startup
00:41:20 UT : Mon Jan 01 2001 : :Time set
System Startup
00:53:00 UT : Mon Jan 01 2001 : :Time set
System Startup
System Startup
System Startup
00:00:19 UT : Mon Jan 01 2001 : :Time set
System Startup
00:04:33 UT : Mon Jan 01 2001 : :Time set
System Startup
