We are running Bh20 at 5.4 ghz. At odd intervals (days apart) it appears to reboot itself.
This is what the error log shows:
16:32:44 UT : 10/20/06 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 1062 Time set
16:32:44 UT : 10/20/06 : File C:/ISIPPC/pssppc.250/bsps/devices/whisp/syslog.c : Line 918 System Reset Exception – External Hard Reset WatchDog
Software Version:
16:32:44 UT : 10/20/06 : File root.c : Line 945 Software Version : CANOPY 7.2.9 Jul 23 2005 01:49:03 BH20-DES
Any ideas?
There was a timing issue with the backhaul code on firmware 7.2.9, eithere downgrade to 7.1.x or upgrade to 7.3.x.
The Timing issue is with 7.3.6 as far as I know…
For clarity’s sake, the issue affects BOTH 7.3 and 7.2 in this way:
Whilst running BHs using either 7.3 or 7.2 you cannot co-locate two Backhauls that are running Software Scheduling.
If all your backhauls are running Hardware Scheduling (which can only be run on P9) then this issue does not affect in any way.
All our BH units are on Hardware Sch.
I have seen all kinds of problems with BH running 7.2.9 and 7.3.6 software. Poor link test, latnecy, rebooting. Downgrade them to 7.1.4.
Vanilla, wich year was whole Malta covered?
Where can I find 7.1 in the pkg2 version?
Malta covered in 2006
Towards the bottom of this page:
http://motorola.canopywireless.com/support/software/index.php?catid=1
vanilla wrote:
Malta covered in 2006 ;-)
Hm, you are not the first ;)
http://motorola.canopywireless.com/pres ... 11606a.php
The network was completed in september 2005.
Malta - 316 km²
Macedonia - 25,333 km²
