What would the effective range of a 5.8 Alvarion VL (21dBm) be with a 15dBi omni antenna at 150’ AGL 35’ ASL?
I know this isn’t an Alvarion forum but since one doesn’t seem to exist I figure I’d pose the question here as I know many of you use it.
Join the WISPA Motorola mailing list: http://lists.wispa.org/mailman/listinfo/Motorola
you’ll likely find an Alvarion user with the answer.
