Hello everyone,
what the rate for PTP600 full. I asked my vendor for PTP45600 and they quote me around 20 k. Whereas they quote me around 11.5 k for PTP54600 lite.
Does anyone know why PTP45600 so expensive?
The reason I want to go with PTP45600 is that they have 25 dBm Tx power even at 256 QAM, whereas in PTP54600 the max power from 64QAM onwards is 18 dBm.
Are you located in the USA? If so I’d recommend you find a different vendor. Check out http://www.lastmilegear.com
I’m not sure if we are supposed to quote pricing…
PTP 54600 Full Integrated - Link Complete (2 units) <$14K
PTP 54600 LITE Integrated - Link Complete (2 units) <$11K
I want to know the rates for PTP45600 as I see a difference of 5K between PTP54600 and PTP45600
nepalken wrote: I want to know the rates for PTP45600 as I see a difference of 5K between PTP54600 and PTP45600
PTP45600 (4.5GHz) is for military use. It's also possible to disable the power reduction feature on the PTP54xxx with a license key if you contact Motorola.
My vendor is contacting motorola on “disabling power reduction feature”. Even in specsheet, the max power from 64QAM onwards in PTP54600 is 18 dB. Is it possible to get same Tx power as PTP45600 with help from motorola
