Re: Outdoor Antennas for ePMP 1000 2.4 GHz Hotspot Conversion?
Pleasdo you have any suggested omni antenna that can be attached to the ePMP 1000 2.4GHz Hotspot radio to help extend the coverage area?
Two options. You can buy the default Omni antenna (5 dBi). Or depending on your region, the following are an option
http://www.microcenter.com/product/413057/Wi-Fi_9dBi_High-Gain_Omni-Directional_Antenna
http://www.syscom.mx/producto/TX24009SMA-TXPRO-68008.html
Above two were recommended in the past.
I've also got some links that might offer you optoins as well -
http://www.itelite.net/en/Katalog/24-GHz-80211-bg//OMD24009V.html
http://www.kenbotong.com/wireless-antenna/wifi-antenna/2.4GHz-Omni-Antennas/
http://www.lanbowan.com/_d4.htm?c=1098
http://www.rfelements.com/products/antennas/
a few other antenna vendors for you to consider:
http://www.smartant.com/index.htm
http://tekfun.com.tw/
http://www.whayu.com/
