Re: Test wireless manager
Are there anyone help me ?
Thank!
coudl you try to install jre7 32bit version for client stratup?
Dear Chaoke,
I have installed jre7.51, as attached image. Furthermore, I have attached logging result unsuccessfully.
I have some questions:
1. Am IĀ able to test without WM license ?
2. Could I install WM software on Windows 7 Utimate ?
Please help me resole problem.
Thanks you so much!
Dear everyone,
Please help me solve this problem.
Thanks very much!
1. User CANNOT use WM without License. However, you can evaluate WM using trial version.
http://www.cambiumnetworks.com/products/software-tools/wireless-manager/
2. Yes, User can install WM on Windows 7.
Regards,
Aman
Dear aman_budhraja
Thank you very much!
