Do they actually want to run the server software on a Mac, or do they just want to use the java client? If they want to run the server running a virtual box, or parallel's they're crazy. If they just want to run the java client there should be no problem doing that, they might have to add a security exception for the IP address of the WM4 server, but yeah, don't see any reason why it wouldn't work.
