What are the corresponding received sensitivity for each of the supported channel width for the PTP650 as specs only defines what is for the 5MHz which is -98dbM?
Gerry,
It's too many numbers to specify them all. You can find this data in User guide starting p. 187.
As an example I attached sensitivities for 5.4 GHz, IP-mode.
- ptp650sensitivities.PNG (49.3 KB)
