# Recommended Contention Slots and "Max Range" setting
**URL:** <https://community.cambiumnetworks.com/t/recommended-contention-slots-and-max-range-setting/49378>\
**Category:** PMP\
**Tags:** knowledge-base\
**Created:** [January 31, 2017, 7:20pm UTC](https://community.cambiumnetworks.com/t/recommended-contention-slots-and-max-range-setting/49378 "2017-01-31T19:20:07Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![CambiumMatt](https://d10gw3vjmzyp8.cloudfront.net/user_avatar/community.cambiumnetworks.com/cambiummatt/32/33533_2.png) [@CambiumMatt](https://community.cambiumnetworks.com/u/CambiumMatt)\
**Post date:** [January 31, 2017, 7:20pm UTC](https://community.cambiumnetworks.com/t/recommended-contention-slots-and-max-range-setting/49378/1 "2017-01-31T19:20:07Z")
</div>
A post to reinforce the recommended use of contention slots (formerly called control slots) in a 450 system.
This applies equally to 450, 450i and 450m.
An additional data point to note is that for every two miles of "Max Range" that is in the system,&nbsp;one fewer symbol will be available per frame. &nbsp;That is, the total throughput will be slightly less due to a higher Max Range setting.
A similar phenomenon occurs when increasing the number of contention slots, but it may make the sector more efficient as described in the attached paper.
- [PMP\_450\_Contention\_Slots.pdf](https://d1okf4ta8xniw3.cloudfront.net/original/2X/4/4c88214ea36ee21342132b5f4388ac511d71e25a.pdf) (452 KB)
