Recovery GPS Firmware
Good day, need to restore GPS firmware, after the update. Prompt that for remote recovery it is necessary?
you can do it from the GUI (graphic interface), for that you must load the same package that is used to update the firmware. If you have a lock on the GPS, you should contact support by opening a ticket for remote assistance . A good previous solution is to de-energize the equipment.
Regards
Oleg,
Please try to reboot the AP through the power.
In case the GPS FW version is not shown on UI, please contac Cambium Support Team.
https://www.cambiumnetworks.com/support/
Thank you.
