hi, i have a problem with epmp 1000 gps_sync, sometimes the BTS (epmp 100gps_sync) loses all subscriber.
afer reboot it, all subscribers link on.
can we help me?
i tried
-to change frequency, but whitout effect
- disabled DFS
on AP:
can we help me?
i tried
- disabled DFS
on AP:
Hello Mariolino,
Could you please provide more information about your issue?
I would be really appreciate it if you could provide System Logs from AP and SM after issue was reproduced.
Described isssue may be caused by GPS signal loss if GPS sync is enabled on AP.
Verify also you have last GPS Firmware version installed.
Please do not hesitate to contact me if you have any further questions.
Thank you.
thanks,
this is my config wifi on epmp gps_sync:
| Operating Channel Bandwidth | 40 MHz |
| Transmitter Output Power | 19 dBm |
| Antenna Gain | 13 dBi |
| Access Point Mode | TDD |
| Downlink/Uplink Frame Ratio | Flexible |
| Wireless Security | WPA2 |
| Satellites Tracked | 7 |
| Satellites Visible |
9 |
Flexible mode does not use GPS for synchronization.
So it should be another reason.
What do you see in System Log when issue reproduced?
Thank you.
