Can somebody help me with a json script to remove the preferred access point from an SM.
Hello,
The specific template depends on if you are updating ePMP or PMP devices. Which ones are you trying to update?
To create a JSON template on your own you would want to use the below procedure to figure out what parameter is used for Preferred AP by setting it to an easily searchable value. Then update the SM via its web UI to have no Preferred AP, export the configuration again and use that value for the setting.
The process for creating your own configuration template for use as User-defined Overrides is:
Sorry for not specifying. This will be for ePMP devices.
The configuration template for clearing out the Preferred AP table is below. If instead you want to remove a single entry from the Preferred AP table, check the steps listed above for creating a new table without the target AP. The full Preferred AP table must still be sent. There is not a delete command for a single entry, at least for configuration templates.
{ "device_props": { "prefferedAPTable": [] } }
