I have a problem with the device product type is ePMP Force 300 ,
the ePTP Master mode doesn’t operate.
Firmware using version 4.4.3. (factory default).
Upgraded to new version 4.5.4 and now ePTP Master mode is operate.
And the problem isn’t solved here.
Why is restarting the device required after every configuration change? Give us the facts about this!
depending on the configuration set (Frequency change, channel width change or power change) the reboot is required on the ePMP range of solutions. The reboot takes few seconds.
Do you have any other issue?
Only several major parameters like Wireless operation mode, Network operation mode require the reboot of the radio.
Other Wireless related parameters require the wireless driver restart that causes SMs disconnect.
In 4.6 FW we are doing optimization to allow apply Tx Power, TRL and edit Wireless MAC Filtering Table without wireless driver restart.
Thank you.
Device name also requires a reboot. It also seems that network changes such as data/management VLAN and Ethernet settings also cause the wireless to disconnect.
