Reversed Link Does Not Have Any Data in cnMaestro
I have a standard TDD flexible frame link that I am using for PTP communications. It is not TDD PTP.
I reversed the link (re-configured the AP to be the SM, and the SM to be the AP). In cnMaestro, I Unclaimed and then Onboarded the devices again. The devices do not show any data now! They register as being up, but the majority of the radio info shows as "N/A".
It appears cnMaestro remembers these radios. What can I change to get the system to recognize their new configuration?
Thanks - Chris
Hey Chris,
Can you please confirm which version you are running on your ePMP AP/SM
Rupam
Firmware is v2.6 on both radios. I'm working with tech support on the issue and will report back here when it is resolved.
