Hi again
Is it possible to split 2 AP’s onto 1 antenna? And if it is what product would you recommend.
Would like to put 2 900 AP’s on 1 omni antenna.
Yes,
Use a combiner. Put one AP at 906 and the other at 924.
You will probably want to put cavity filters on both AP’s as well.
However, you will lose about 4dB from each AP through the cavity filters, connectors, and splitter so you need to decide if you can afford the loss.
