Hello, I'm trying to build ring between 5 sites, by LinkPlannerI found that there I need 10 units of PTP 820S, I just wonder if I can build it with only 5 units of PTP 820G Dual?
Yes.
Thanks!!!
If you require G8032 for ring you will need the 820G anyway, as its the only one that supports it. It is a licence activation though, so dont forget to add it to your BoM.
