Hello,
I have a question about cnPilot
Is it possible to roaming two cnPilot on two different networks(VLAN)?
Best regards.
Hello,
Best regards.
Hello Legos,
I’m not exactly sure what you are asking. Roaming requires the same SSID on each AP included in the Wifi network. Are you asking if one AP can have SSID "Corp’ for example, on VLAN 1000 on AP1, and ‘Corp’ SSID on VLAN 1100 on AP2? The answer is yes, you can do that. You cannot have 2 different VLANs on a single SSID on one AP, if that makes sense to you. I hope I answered your question.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
