I need some help with an integration issue in Rodopi/Prizm. The information from Rodopi is everything on their end (ie. modules, patches, updates) are done and the only thing left is to configure an API in Prizm to allow them to communicate back and forth. I did not do the Prizm install but I have been looking through the guide. There is nothing that I can find in the guide or online that would point me in the direction to configure the settings for the API that Rodopi needs.
Any help in this would be appreciated.
Joe
Rodopi requires use of the Northbound Interface of Prizm. You should refer to the User Guide and the SDK for instructions on enabling and utilizing the Northbound Interface.
