For the linux users out there, there are a couple of issues with the CNUT distributed by cambium:
- The launch script uses windows style newlines, this means that
sudo bash /usr/local/Canopy/networkupdater/CNUTLauncher.sh
Will issue errors like:’: not a valid identifierexport: CANOPY_HOME<br>': not a valid identifierexport:
JAVA_HOME
CNUTLauncher.sh: line 7: $’‘r’: command not found
’: not a valid identifierexport: `PATH
CNUTLauncher.sh: line 10: $’‘r’: command not found
CNUTLauncher.sh: line 12: $’‘r’: command not found
CNUTLauncher.sh: line 33: syntax error: unexpected end of file
The easiest fix is to convert the script into linux format by using the dostolinux utitityfromdos CNUTLauncher.sh - You will need to launch the script as root (by using sudo), otherwise you will get a message saying
Failed to start http Server:
java.net.SocketException: Permission denied
So far this, if I forget anything or any of this has been fixed/changed on newer versions, please ping me to update this doc.
