To activate this do you only need to add a secondary (tertary, etc.) color code in the SM?
I ask as I see the AP’s also have a couple of configuration parameters in the radio tab. These are:
Subsriber Color Code Rescan (in minutes) and,
Subsriber Color Code Wait Paiod for Idle (in minutes).
Yes, on the RF page of an SM you can specify I think 10 color codes. Once you start adding more a drop-down box becomes active letting you define the priority.
