So do you use shields as well with these mounts? Or just the antennas? If you dont use shields are you concerned about self interference from the cluster mount being so close together to each radio or does epmp radio not have a problem like the UBNT gear? I know with my UBNT 2.4 gear I would be able to do this.
any 802.1AF switch will work for the GPS APs. the integrated units can be powered by 24v poe, any polarity.
NO gound lug on that thing... i would'nt do it if i were you....
netonix makes a good topside switch that has grounding. www.netonix.com
ground potential difference can be you're worst nightmare. for us, NO grounding, not installed. period. chris at netonix has a pretty easy to understand write up on ground potential issues if you are not fimilar with it.
UBNT isn't exactly known for having the bugs worked out of there products at launch either. not sure how old that thing is.
but it would power those APs if you wanted to use it.
X-pol in noisy and non line of sight situations is extremely helpful. Also if you compare the antennas edges to the competition you’ll see its much smoother. Most manufacturers antennas are -6 db at the edge, these are -3. They’ve got smaller “fingers” of wasted RF going down and back than most. Important so near tower cpes don’t hear the opposite ap as well. Overall if you compare the radiation graphs you’ll see its cleaner more even signal generated
