How can I go about finding out what the sector is on a PMP 450 series Accesss Point that was put up in the field and there is no record of what it was out of the box?
Hmmm that's going to be a tough one without physically visiting the site. A couple ideas to try...
- You could use binoculours or a camera with a zoom lense
- You could use a drone
- You could find out who you bought the equipment from and look through sales records with the distrubutor
All good suggestions Eric... unfortunately, the radio itself keeps no information on the antenna that's attached to it (aside from gain). Visual clues may be the only way to tell.
Do you know if it's a Cambium Networks sector antenna or a third party?
