Am i the only one having issues with the Sector Visualization feature of cnMaestro?
Some sectors show up on the map, and some don't.
Can't find any correlation for the ones showing up vs the ones that aren't.
If i fill in the required values for Height,Azimuth, Elevation and Beam Width, and cnMaestro can talk to the AP and read it's frequency, then why are some showing up, while others don't?
Going to assume it's just a buggy feature at this point.
Also some will not let me have a negative elevation (which I'm assuming is downtilt?). Sometimes if I save it as 0, and then go back to the configuration, it will let me put in a negative value, but sometimes it won't.
@Justin_3, are you using cloud? If so, any chance you can invite me to your account so that I can see the issue. I'll send you a private message in community.
There's only 1 network and none of the towers have the same name
I received an email from cambium yesterday asking if the engineers could remote in and take a look
It will probably be a couple days before mine and their schedules align to allow this but I'll post the results to this thread in case anyone else runs across the same issue
In the left-hand tree, the three dots button to the right of the tower can be clicked to bring up a menu where you can click Edit to change the tower location.
I think there's a few issues here that we'd like to understand better. I have forwarded this post to my collegues. As a starting point can you tell us the cnMaestro version you're running, the Role of the user account you're using and if you have MSP enabled? Thanks in advance. I don't want to make any assumptions.
We use the Version 2.1.0-r21|.
I think I'm an operator. If i go in Application, Server, i see this menu (If this thing can help you understand what role I exactly have.)
