Does anyone have any experience with the performance of the LT-18 refelector versus the Motorola 27RD at 5.4?
The performance is probably comparable to any of the satellite dish or motorola reflectors at 5.8 ghz. They are all pretty similar. You can get a better price than this by going to eddco.net and buying a palette of dishes. In palette quantity, the dishes are basically around $40 each. If you specifically buy the canopy model then the dish’s mount arm fits the plastic radio mount with perfect fitting plate to hold the radio on for the long haul (no hose clamps)
