Serial Number
I have remote links and i do not seem have records of their serial numbers, Can i get the serial number of a unit from the GUI or otherwise ?
Ben,
The ESN (or MAC address) are available from the GUI but not the MSN. You may try to contact our support center if you have the MAC address to search for the MSN.
http://www.cambiumnetworks.com/support/contact-support
or http://www.cambiumnetworks.com/support/open-a-support-case
