I was wondering whether it's possible to set the Cyclic Prefix via snmpset ? I found the correct OID to read it but I'm getting a timeouit when I try and set it to something else.
SNMP just seems like the fastest way of doing this since it's pretty easy to script / automate. I really want to prevent logging into each PMP430 SM and manually setting the value.
### Reading works, I'm presuming a value of "1" = One Eighth and a value of "2" = One Sixteenth ?
snmpset -v2c -c snmpWIRELESS 10.4.22.189 .1.3.6.1.4.1.161.19.3.3.2.81 i "2"
Timeout: No Response fromn 10.4.22.189
Thanks in advance,
-steph
Steph,
We had a bug with this OID and was fixed in 13.4.1 and 14.1. Yes, this is be possible on PMP 430 SMs via SNMP. The OID is cyclicPrefix in whispBox is correct: .1.3.6.1.4.1.161.19.3.3.2.81.0
And the integer values are: INTEGER {one-quarter(0), one-eighth(1), one-sixteenth(2),
To test the fix you can upgrade to 13.4.1 beta, Or wait for the 13.4.1 official which is planning to go official next week.
