Setting up a large (fixed?) Wi-Fi network
Hello,
The colored dots on the map show the locations where the internet distribution and antennas will be located. I have some lack of knowledge about Cambium Networks products.
Therefore, I am waiting for your valuable ideas.
Red dot internet distribution center; the turquoise dots are the positions where the antennas are located.
The subscription system is; It will be in the form of 25/8, 50/10, and 100/20 (download/upload). The height of the buildings will be 15 meters on average, and the height of the antennas will be between 15-20 meters.
Which antennas would you recommend using in order to deliver 2.4GHz and 5GHz signals to the end clients and to have a strong structure in the background?
Thank you.
