gravel
(gravel)
1
Hello,
I am trying to set the Subscriber Module Scanning freqeuncy list via ssh.
I found into the cli guide the command: config set wirelessInterfaceScanFrequencyListForty
and I tried passing varius parameters like 5500-5740; 5500/5740; 5500,5740
e.g. config set wirelessInterfaceScanFrequencyListForty 5500,5740
to select all frequencies in that range but at best it was selected the first freq (5500)..
How can i select a contiguos range of frequencies via ssh command?
Fedor
(Fedor)
2
@gravel wrote:
Hello,
Please use the following format:
config set wirelessInterfaceScanFrequencyListForty "5840 5845 5850"
config save
config apply
Thank you.
