Although it is pretty old it still explain the basics. For the CCTV you would probably want to setup 30/70 downlink-to-uplink ratio to have more throughput in the uplink. Other than that it should be pretty straightforward.
Maximum cable length for Ethernet is 328 feet(100 meters). Power supply was also build with the voltage drop of the 100 meters cable maximum length in mind.
