Several force 200 units wont see 40 mhz wide channels?
Hello Jlint,
Sorry for the troubles. Which sw version are you using? Do you see issues when 20MHz channel is used? Are you selecting specific frequencies for the radio to scan? Are your radios configured for a specific country code?
Regards
because of the distance 13.7km, we opted for 40mhz, country is kenya(given licence)
i will try to select the all channels again today and see if we shall manage to scan the other radio.
Hello Jlint,
Thanks for the info. If no frequencies are selected in the SM, it should by default scan all frequencies. As the SM scans, it should list detected APs in the Monitor->Wireless page. If for any reason you still have issues with 40MHz, please try 20MHz as well. Please let us know how it goes.
Regards
i still cannot see my ap at channel 20mhz?
Hello Jlint,
From Configuration->Radio, which Driver Mode is selected for both AP and SM? I am asking because TDD and ePTP drivers are not compatible, so both boards need to be using same driver.
Regards
