Can someone recommend a particular Multi-Mode Fiber SFP for the PTP 600 radios.
We have an upgrade kit for multi-mode fiber SFP on PTP 600. The kit includes the SFP module, an extended cable gland, and an access key that provides the license to use the SFP. It's "PTP 600 Series Multi-Mode Optical Conversion Kit", part number WB2312.
If you've not done so already, you'll need to purchase the upgrade, exercise the Access Key and generate a new License Key with the SFP capability enabled, and install the SFP module and extended cable gland.
Mark
