Hi Everyone
We are looking to buy some shielded cat 5 for use outdoors. If anyone here knows of a good supplier we would love to know.
Thanks in advance
We use Best-Tronics Inc. cables on all our towers, incredibly expensive, pre-terminated cables. BUT, they are lifetime warrentied, so when we do get a bad cable, we send it back, and they send out a new one. Up front cost is truly high, but for the amount of cables we go through replacing after lightning strikes, it ends up being well worthwhile. I’d say for overall “failure rate” due to bad termination, we only have to replace 10 or so cables across 800+ towers in a year.
