Shielded outdoor fiber for 400c
Hi all, just wanting to see what is your go to outdoor shielded fiber, pre-terminated, used on tower sites?
we use preterminated shielded fiber, but we use to install it inside a PVC outdoor pipe to add an extra protection.
we have a few F400C in sahred sites , so we never know who is going be working there…
hope it helps
Thank you for your reply, what brand did you go with? Any specific vendor you purchased from?
im from spain, here we use KEYNET as supplier, other times depending on stock we have even bought from amazon
here you have a link so you can see it
https://www.amazon.es/dp/B09JN31TPW?ref=fed_asin_title&th=1
regards
Thank you! Really appreciate it
What transceiver brand do you go with?
The cables from amazon, did you use a 1G or 10G Transceiver?
we are using mikrotik in most of our links, we also have 2 links with the amazon cable and mikrotik working pretty fine
Appreciate all your help
