Silicone or dielectric grease?
Does anyone else put silicone or dielectric grease in the RJ-45 connection in their APs and or BHs?
HI PcPolo,
we also put silicone in the RJ45 ports in our modules, but only to PMP320, because we only use pre assembled patch cables, so the pg plugs wont work. After that we put sanitary silicone over the plug, so that no water should come inside.
greets from Germany
Linus02
