Is a CMM4 still required when implementing a single 120-degree sector AP only?
If you want it to be timed, which I believe is a requirement in that band, yes. I am not sure if the Wireless Beehive SyncInjector stuff works, though.
If your AP is in a lab you can just use the appropriate POE injector.
