On your experience what is the best configuration to apply on SM (with Nat enabled, HW shcheduling) and on APs when custumer whant use Skype or Messenger (voice + video).
Should DiffServe Config page be setted in a special way?
we use standard settings and skype seems to work fine.
As far as I know Skype do not use diffserv (yet!)
Also they don’t use any of G.### codec’s they use some other codec.
Skype and messenger are both very very robust. No need to DiffServe or prioritize traffic.
Jerry,
when you say robust, what do you mean ?
