@NOW wrote:
Product Name cnPilot R200PHardware Version V1.3Loader Version V3.30(Oct 28 2016 14:51:31)Firmware Version 4.3.1-R1(201612201723)Device-Agent Version 2.66SInce we have done this firmware update the dialout seems to take 5-10seconds longer to connect a call then before.Please advise.Thanks,
Could you please send us logs & config from the AP, to support@cambiumnetworks.com?
Also, what was the previous device firmware? Any other changes (network settings, SIP server etc), or just after the firmwrae upgrade you see the extra time on the dial-out?
thanks
thanks
Sent
Cant remember I deleted my note after we did the update but from what I can put together it would have been what was available in Sept 2016
Any other changes (network settings, SIP server etc), or just after the firmware upgrade you see the extra time on the dial-out? After the update I had to change the Ring Voltage(40-63 Vrms) on line to ring a bell setup and Impedance Matching
