SM and AP serial numbers
Does anyone know if it is possible to get the unit serial number from the firmware . I have a number of SM’s and AP’s in my network and I now need to correlate the serial numbers with the various users.
There seems to be no way. Mabye you should consider using the MAC address as a serial number. You can use the last 3 bytes as the 1st 3 will be the same.
