SM dont access from RF IP or LUID and Bandwidth problems
Hello, recently i was using bam 2.0. my network has been growing and the SM troughtput was slow…
I stoped the bam service and setted manually on each SM the bandwidth, the firts days was working fine but sometimes i can access the SM trought RF or LUID. i was searching the problem, i noticed than SM has 2000Kbps assigned by AP. the extrange is that on AP is setted to SM as source of configuration. when i reset the SM take the correct values. and voila!! i can access again the SM.
Today i noticed this info. i saw a CLMP ??? i dont see this on forum. what is this?
Anyone has similar problems?
LUID: 002 : MAC: 0a-00-3e-50-2b-f0 State: IN SESSION (Encrypt Active)
Site Name : FOCA
Software Version : CANOPY 7.3.6 Oct 24 2005 12:06:56
FPGA Version : 020205 (DES) P9
Session Timeout: 19, AirDelay 33 (approximately 0.31 miles (1617 feet))
Session Count: 1, Reg Count 1, Re-Reg Count 1
RSSI (Avg/Last): 1444/1426 Jitter (Avg/Last): 2/2 Power Level (Avg/Last): -47/-47
DnRate(CLMP): 128 DnLimit(CLMP): 10000 UpRate(CLMP): 128 UpLimit(CLMP): 10000 (kbit)
LUID: 003 : MAC: 0a-00-3e-50-27-96 State: IN SESSION (Encrypt Active)
Site Name : SAO-Santa Marta
Session Timeout: 19, AirDelay 70 (approximately 0.65 miles (3430 feet))
Session Count: 1, Reg Count 1, Re-Reg Count 0
RSSI (Avg/Last): 997/1008 Jitter (Avg/Last): 1/2 Power Level (Avg/Last): -56/-56
LUID: 004 : MAC: 0a-00-3e-50-2c-18 State: IN SESSION (Encrypt Active)
Site Name : Proyectos Turisticos
Session Timeout: 25, AirDelay 59 (approximately 0.55 miles (2891 feet))
Session Count: 2, Reg Count 2, Re-Reg Count 0
RSSI (Avg/Last): 1034/1041 Jitter (Avg/Last): 2/2 Power Level (Avg/Last): -55/-55
LUID: 005 : MAC: 0a-00-3e-50-28-37 State: IN SESSION (Encrypt Active)
Site Name : Metroagua
Session Timeout: 20, AirDelay 60 (approximately 0.56 miles (2940 feet))
RSSI (Avg/Last): 756/757 Jitter (Avg/Last): 2/3 Power Level (Avg/Last): -69/-69
DnRate(BAM): 128 DnLimit(BAM): 10000 UpRate(BAM): 128 UpLimit(BAM): 10000 (kbit)
LUID: 006 : MAC: 0a-00-3e-50-2b-e7 State: IN SESSION (Encrypt Active)
Site Name : Corpamag
Session Timeout: 24, AirDelay 42 (approximately 0.39 miles (2058 feet))
Session Count: 2, Reg Count 1, Re-Reg Count 1
RSSI (Avg/Last): 1266/1253 Jitter (Avg/Last): 1/1 Power Level (Avg/Last): -51/-51
DnRate(CLMP): 512 DnLimit(CLMP): 10000 UpRate(CLMP): 256 UpLimit(CLMP): 10000 (kbit)
LUID: 007 : MAC: 0a-00-3e-50-27-a9 State: IDLE
Session Timeout: 0, AirDelay 125 (approximately 1.16 miles (6125 feet))
RSSI (Avg/Last): 673/669 Jitter (Avg/Last): 2/2 Power Level (Avg/Last): -72/-72
DnRate(AP): 20000 DnLimit(AP): 500000 UpRate(AP): 20000 UpLimit(AP): 500000 (kbit)
LUID: 008 : MAC: 0a-00-3e-50-27-a4 State: IN SESSION (Encrypt Active)
Site Name : Rokola.Net
Session Timeout: 17, AirDelay 54 (approximately 0.50 miles (2646 feet))
RSSI (Avg/Last): 1164/1164 Jitter (Avg/Last): 1/1 Power Level (Avg/Last): -52/-52
DnRate(CLMP): 384 DnLimit(CLMP): 10000 UpRate(CLMP): 192 UpLimit(CLMP): 10000 (kbit)
LUID: 009 : MAC: 0a-00-3e-50-2c-0f State: IN SESSION (Encrypt Active)
Site Name : Leonardo Acevedo
Session Timeout: 6, AirDelay 101 (approximately 0.94 miles (4949 feet))
RSSI (Avg/Last): 915/910 Jitter (Avg/Last): 2/2 Power Level (Avg/Last): -60/-60
LUID: 010 : MAC: 0a-00-3e-50-2c-8e State: IN SESSION (Encrypt Active)
Site Name : Servicont E.U.
Session Timeout: 27, AirDelay 73 (approximately 0.68 miles (3577 feet))
RSSI (Avg/Last): 820/864 Jitter (Avg/Last): 2/3 Power Level (Avg/Last): -67/-64
In your ap in configuration, did you select sm?
Configuration Source X SM
BAM
BAM+SM
Since I am not running BAM we selected sm
Be sure and set your ap wide open also
i hace seleted BAM.
The way I understand it,If you are not using BAM you need to select SM
I returned to use BAM. i have seleted to AP autehntication required and BAM as configuration Source.
this must be normally
LUID: 003 : MAC: 0a-00-3e-50-26-0a State: IN SESSION (Encrypt Active)
Site Name : kokorico
FPGA Version : 070605 (DES Sched) P9
Session Timeout: 0, AirDelay 128 (approximately 1.19 miles (6272 feet))
RSSI (Avg/Last): 1814/1332 Jitter (Avg/Last): 1/1 Power Level (Avg/Last): -38/-48
LoUpCIR(D): 0 LoDnCIR(D): 0 (kbps)
Rate : VC 19 Rate 2X/2X
BUT THIS NOT!!
Notice that says CLMP not BAM what does means CLMP??
I saw the same CLMP. We also use BAM but mainly for auth.
