Hi all,
I’m doing some scripts to provission my SMs and do the things easier.
Through SNMP I can do many things however I can’t find a way to upgrade firmware without using CNUT or PRIZM.
Is there a way to do that through FTP, or TELNET? I could write php scripts then to automate the task.
Thanks very much in advance,
Zeta
I believe all CNUT/Prizm are doing is using Telnet. From what I can tell it’s just TFTP’ing the file and using the burnflash command. Probably want to verify that though!
I believe CNUT just uses telnet and FTP.
Well… I’m doing something wrong. When I FTP the .pkg2 file into SM I get “Insufficient storage space” error (of course! it is 8MB file).
So… what is exactly what I have to send to the SM?
Zeta
I believe you need to extract the pkg files and upload either apboot.bin or smboot.bin (I think those are the filenames).
Ok… sorry about my ignorance… How can I extract the files inside .pkg2 package? :?
Thanks in advance
One word: A M A Z I N G!
