SM per AP Inventory
Hiello.
Sorry if this has been asked before. I couldnt find something similar.
Is there a way to obtain an inventory report of SM per AP? For example:
AP1
   SM1
   SM2
   SM3
AP2
   SM1
   SM2
   SM3
Inventory does provide this information. However I see no way to determine which is the AP for each SM.
This information is available through the Report > Data Export feature. You can select the "Connected AP MAC" from the list of fields and generate a CSV with data that includes both APs and SMs (essentially children of the node chosen in the tree). The SMs will have the MAC Address of their AP.
Thank you!
