You said:
OK, if you don’t know which colour code you should use, is there a way that the SM can scan and find the best AP to connect to and then you can decide what Color code to assign the SM to?
When you are doing an install, the SM has a page called AP Eval Data. This allows you to look at all of the AP’s the SM can see. Then you select the color code for the AP with the best signal and lowest jitter. Note: You have to configure the SM for hardware or software scheduling first depending on your AP configuration or the SM won’t see anything.
We set our SM’s to allow all frequencies. If we need to move an AP to another frequency to evade interference, we want the SM’s to be able to follow without having to go in and change each SM’s frequency.
One thing you will find out about Canopy is that for the first 20 minutes after installing an SM, the AP is training the SM. During this time the performance will be less than you would expect. After you get the SM powered up, do something else like start cleaning up, configure the customers router, staple the cable, seal the holes, etc. When you come back to the SM you will find that the performance has improved.
Regarding the original question, the SM’s that are showing -44 and -35 are WAY too hot in signal strength. This is going to cause you big troubles as you add more subscribers, and the effective range on your system will be lower because you are blinding the AP with too much signal from the closer SM’s.
The solution is to set the SM to low power, and turn it away from the AP. Antenna patterns are not perfect lobes, and the backside of the SM will pick up plenty of signal. Try to get the signal level down below -65dB. You may need to put the SM in side the building.
As close as you are, why don’t you run a cable from your switch to the end user and take down the SM?
