Sometimes some SM become unreachable via management IP or via AP (using proxy), I have this problem on various APs.
I'm using Management VLAN and the SM has NAT enable, when the SM "stuck" the NAT still works but it randomly drops sessions or some IP addresses on the same network are unreachable..
I never had this problem with older FSK radios
This is a dump of the SM after a "Drop Session" performed on the AP
******System Startup****** System Reset Exception -- User Initiated Reset Software Version : CANOPY 14.1.1 SM-DES Board Type : P11 Device Setting : 5.4/5.7GHz MIMO OFDM - Subscriber Module - 0a-00-3e-b2-07-aa<br />No valid accounts configured. Using default user account FPGA Version : 110815 FPGA Features : DES, Sched; 10/14/2016 : 14:48:18 UTC : :NiFreeBuf(): Invalid NiBuf:22f4000 Hdr:5b9b on Src:31864 SrcIF:126 Dst:40716 Alc:2038 Len:11069 Cop:215 10/14/2016 : 14:48:18 UTC : :Buf ptr = 0x022f4000Current TxBD pointers: FirstBd: 0x80b76100, EndBd: 0x80b76b90, UsedBD: 0x80b762c0, FreeBD: 0x80b762c0
Current Buf Contents (first 512 bytes):
0x022f4000: 00000000 00000000 00000000 00000000
0x022f4010: 00000000 00000000 00000000 00000000
0x022f4020: 00000000 00000000 00000000 00000000
0x022f4030: 00000000 00000000 00000000 00000000
0x022f4040: 35e6ac9a 33392e32 35352e32 35352e32
0x022f4050: 35303a31 3930300d 0a434143 48452d43
0x022f4060: 4f4e5452 4f4c3a20 6d61782d 6167653d
0x022f4070: 3130300d 0a4c4f43 18448101 81000066
0x022f4080: 7474703a 2f2f3139 322e3136 382e312e
0x022f4090: 323a3139 30302f69 67642e78 6d6c0d0a
0x022f40a0: 4e543a20 75756964 3a396630 38363562
0x022f40b0: 332d6635 64612d34 6164352d 38356237
0x022f40c0: 2d373430 34363337 66646633 370d0a4e
0x022f40d0: 54533a20 73736470 3a616c69 76650d0a
0x022f40e0: 53455256 45523a20 69706f73 2f372e30
0x022f40f0: 2055506e 502f312e 3020544c 2d575237
0x022f4100: 34304e2f 342e300d 0a55534e 3a207575
0x022f4110: 69643a39 66303836 3562332d 66356461
0x022f4120: 2d346164 352d3835 62372d37 34303436
0x022f4130: 33376664 6633370d 0a0d0a77 93e2ad00
0x022f4140: a2ca2bf5 9a79c2e6 c29fdee1 864db568
0x022f4150: 2ae66eea 4d283b79 298698fe bafb7e84
0x022f4160: b5b15403 674a240f 3799069f d279c9b1
0x022f4170: 11a46cc2 fc957aec 193f8101 81000001
0x022f4180: d5b56bbd 4303fec2 c7fc3839 1df2ce91
0x022f4190: 036557ad 90493ff3 ed584245 e6606889
0x022f41a0: a39c61ce af44184a edf028ea a6018f1b
0x022f41b0: c03c600f 50e272cc 254b2194 b8e0903e
0x022f41c0: 469d9ba2 c1275beb 29042d93 c6a8bfdf
0x022f41d0: 0fdd46fd 49c7b0b9 a8f083d1 6155ca70
0x022f41e0: 4c1334a1 16820618 7d632460 78a84081
0x022f41f0: 526b08a9 483070e3 6bfec75c 8d1a957b
10/14/2016 : 14:48:18 UTC : :PktInfoHdr Contents:
0x022f46c0: 00281200 00000000 022f4012 00000000
0x022f46d0: 00000000 00000000 00000000 08068100
0x022f46e0: 00000000 00000000 00000000NIBUFHdr Contents:
0x022f4794: 9a759f0c 5b9ba7a5 989d7e4e ab68134d
0x022f47a4: 65bb562b 7c7807f6 2b3d7ed7 7b5786b6
0x022f47b4: 2403914c b86c5f21 6078e326 00000000
0x022f47c4: 02000000 00000000 00000000 00000000□PPPoEInfoHdr Contents:
0x022f4788: 0e4786a2 b209cf60 897d7e92
□GatherHdr Contents:
0x022f4738: 022f4000 022f4780 022f400c 00000000
0x022f4748: 00000000 00000000 0000000c 00000004
0x022f4758: 00000030 00000000 00000000 00000000
0x022f4768: 0000000010/14/2016 : 14:48:18 UTC : :FatalError()
Stack Dump information:
Current context Task: SYNC
Current Stack: 2%
Max Stack: 33%
r0: 00000000 r1: deadbeef r2: 00000000 r3: 92000004
r4: 00000000 r5: 00370da4 r6: 009566a4 r7: 009566a4
r8: 0027632c r9: 005da756 r10: 005da783 r11: 00000000
r12: 00000000 r13: 0000000a r14: 80a5ff00 r15: 08001bac
r16: 022f4000 r17: 80a50c7c r18: 00000000 r19: 00000001
r20: ffffffdf r21: 08080068 r22: 0000000c r23: 0057f644
r24: 00000000 r25: deadbeef r26: 00584930 r27: 00956770
r28: 0000000c r29: 00006efc r30: deadbeef r31: 080008c8
Task Stack Dump:
0x00956688: 0000001d 00006efc 0000001e deadbeef
0x00956698: 0000001f 080008c8 000066ac 009567c0
0x009566a8: 009e3ce4 00953c58 00000bff 00030005
0x009566b8: 0093bd80 0093be48 00000000 00000000
0x009566c8: 00000000 00000001 00000000 05050020
0x009566d8: 01000000 00e47fc0 00000000 00000000
0x009566e8: 00000000 00000000 00956c54 00000110
0x009566f8: 00000fd8 53594e43 00000000 00000000
0x00956708: 009566a4 000003ca 00002ffc 00000024
0x00956718: 00956720 00000000 009566fc deffcf04
0x00956728: 00000004 0000001b 0000001b 00370ef4
0x00956738: 00a1e52d 00472e98 022f4000 0095674c
0x00956748: 0006ccb0 0037068c 0000048a 0095675c
0x00956758: 0006d1c4 0037068c 0000048a 00000000
0x00956768: 00000000 0000000c 080008d8 00005b9b
0x00956778: 00007c78 0000007e 00009f0c 000007f6
0x00956788: 00002b3d 000000d7 00000015 00000000
0x00956798: 00000000 00000000 00000015 0057f644
0x009567a8: 0000000c 08080068 ffffffdf ffffffe0
0x009567b8: 00000020 80a50c7c f000819f 0000000c
0x009567c8: 000e0de4 f0002c30 0057f644 f0002830
0x009567d8: f0002430 f0002030 80a70300 000e4a6c
0x009567e8: 000000ff 0047fb64 00000000 00000000
0x009567f8: 00000000 00000000 00000000 00000008
0x00956808: fffffffe 000976f0 00000000 00000000
0x00956818: 00000008 000978fc 00480194 000bc26c
0x00956828: 00011c00 00048768 53594e43 00000000
0x00956838: 00000001 00000000 02371000 00000000
0x00956848: 00000000 02371000 00000003 004803a4
0x00956858: 02371000 0007beec 00000068 000bc26c
0x00956868: 00ffffff 00000003 00000001 00936db4
0x00956878: 08002698 00956880 00000000 00000000
0x00956888: 00000001 00000001 02371000 00000000
0x00956898: 0047fb64 0009ae20 00000000 00000000
0x009568a8: 00000001 00000000 00000000 00000000
0x009568b8: 00000000 00000000 00000000 00000000
0x009568c8: 00000000 00000000 00000000 00269fa8
0x009568d8: 00000000 00956b40
10/14/2016 : 14:48:18 UTC : :Forced reset;
