SM sustained downlink & uplink data rate stuck at 128k
Hello All,
Has anyone experienced this? I have a BSP of
uplink rate: 256k
uplink burst: 256k
downlink rate: 512k
downlink burst: 512k
but logging into the SM it gets the correct burst values, but not the sustained up & downlink values w/c are STUCK in 128k only. (see bold lines below)
i tried rebooting the SM, temp changing to another BSP, upgrade/downgrade firmware, etc. but this seems to be a persistently annoying issue and my customers are complaining. When we disable Prizm auth on that AP, the SM get free-for-all BW and they stop complaining. This happens randomly as some SM on the same AP get the correct BSP but not others.
Software Version : CANOPY 9.3
Software Boot Version : CANOPYBOOT 1.0
FPGA Version : 061808 (DES, Sched, US/ETSIv1.3.1) P10
Session Timeout: 0, AirDelay 11 (approximately 0.31 miles (1617 feet))
Session Count: 32, Reg Count 32, Re-Reg Count 6, Session Uptime 05:11:35
Jitter (Avg/Last): 4/4 Power Level (Avg/Last): -74/-77
Sustained Uplink Data Rate (BAM): 128 (kbit)
Uplink Burst Allocation (BAM): 256 (kbit)
Sustained Downlink Data Rate (BAM): 128 (kbit)
Downlink Burst Allocation (BAM): 512 (kbit)
Low Priority Uplink CIR (D): 0 (kbps) Low Priority Downlink CIR (D): 0 (kbps)
Rate : VC 18 Rate 1X/1X
We saw that a few times but it was related to SM hardware/software being very old compared to the AP’s. We changed out to newer hardware and we were good to go.
