I've got an ePMP 1000 2.4 GHz SM, internal antenna. I'm using 2.5.2 firmware. For some reason, with this unit, I cannot bring up the web interface thru the wireless network using the admin IP address I assigned. If I switch to https then it'll work on port 443. It works with either thru the wired interface. I have other SMs configured the same way and they work without issue.
So I've just had another one do this. I've reviewed the configuration. I'm using NAT for the ethernet interface and can access it with the NAT DHCP address. But with the wireless admin address, it only works if I set https mode, not plain http mode. SSH works to the wireless IP address and SNMP does as well. Any ideas why port 80 isn't responding?
