Running 16.0.1, can anyone point me to the OIDs to use to get the modulation on both upstream and downstream from an SM?
I’m not sure if this is exactly what you’re looking for, but you can see the link quality stats of all SMs under a given AP by looking at the whispApsLQI OID in the WHISP-APS-MIB. It contains 3 tables, corresponding to the low, mid, and high data gathering intervals. That table contains information on each SM’s uplink and downlink mod rates, among other LQI stats. Again, to clarify, you would get this data from the AP via SNMP, not from the SM.
Regards,
-Al
