The 100% frame utilization stat is a bug... I believe they're fixing it in the next release... as to the OID for these two values, I'd love to know as well :-)
those numbers are the total number of frames used per second, you'd need to do some math in order to figure your %%%% or if your software can do some math and use fields 1.3.6.1.4.1.17713.21.2.1.51 and 1.3.6.1.4.1.17713.21.2.1.52 with them, you can figure your percentage.... or monitor both and realize when 53 and 54 get near 51 and 52 your frames are getting filled.... not exactly the same, but can give you some idea until that specific MIB is available
Looking at these OIDs more closely...These are 1-second period results.
I believe the PMP450 has 1-, 5-, and 15-minute period OIDs to poll the frame utilization percentages. I would like to see those periods in ePMP as well whenif frame utilization percentage is ever implemented in SNMP.
Oh, I just realized these frame usage OIDs are being returned as Counter32 instead of Integer, UInteger32 or Guage32. This is a very bad decision.
Counters go up over time and never go down, so any rrd-backed application is going to assume any time a sample is smaller than the prior, that the "counter" rolled over and will spoil the visualization of the data.
